Installed RLI (reserve lift indicator) from Alpha Systems and pitot tube on wing, Installed prop spinner and cowling, hooked up aileron control cables and control rods, Installed UHMW blocks on aileron control tubes. I worked on wing to cabin covers. Checked out the wing set and it is still right on were it belongs. Dang it is so close yet so far to being done. The drawing show a 370-3 washer between the control tube to the aileron, it does not tell you to but you will need to drill it out to the AN-4 bolt and you will need two of them on each aileron, Also you will need two on the control tube connection in the cabin. Installed right strobe/navigation lite and wired to wing tip wiring.
