BushCaddy ELSA
Date:  5-31-2009
Number of Hours:  4.00
Manual Reference:  None
Brief Description:  Navigation light wiring and wing tip on left wing
It seams to take longer to do things now. I ran the wire through black conduit that I purchased from Vans RV store along with the wing tip navigation lights off set. I installed a six pin connector on the left wing and left side of the fuselage. Tested light and it works great. Started running wiring for the right wing navigation light and installed three pin plugs. I still have to run the wire to the right side of the cabin. I installed left wing tip with navigation light on it. I installed a two inch vent on the left door already had one on the right door. Sure does not look like I did a lot but it took all of 4 hours to make all the connection and install nut plates and all the crimping of wire connectors and heat shrink.
Oil cooler airduct fitup
strobe and clearance lights
Conector on both fuselage and wing
