BushCaddy ELSA
Date:  4-9-2009
Number of Hours:  1.50
Manual Reference:  None
Brief Description:  Securing wiring FWF and parking brake valve
I had used nylon tie wraps and plastic tubing to support my wiring fire wall forward and after reading some exchange of post on a yahoo group about how they could wear on the engine mount and how you it is better to use Adel Clip I ordered an assortment of WDG clamps as they only have one size of Adel clips and I need a verity of sizes. I used 10 size 10 clamps along with 8 size 3, four size 2, 1 size 12 for the oil breather hose and 4 size 4 clamps. I will more than likely use more under the panel and other places. I install the parking brake valve from Matco a PVPV-1 witch has now been replace with PVPV-D. I am using the 1/8 inch tubing for my brake line.
old way tie wraps and plastic tubing
Changes made with WDG clamps
parking brake valve
parking brake valve
