Continued wiring of the panel and connection all the wires and straighten them up under the panel. Ran all the grounds to one place on the F/W and the ground buss is connected directly to the battery Neg. Ran ground wire from starter bolt to battery as per Jabiru instruction Bulletin.
Even with the camera flash you can see the displays
