Brief Description: Continued working on wiring and fuel system
I did not like the way the tubing had to be formed around the inside corner in the fuselage and was right next to the aileron cables so I installed a flared bulkhead fitting like I used in the front and ran the tubing in the aft cabin area. Cleaner job and will be easer to inspect and make sure no leaks. I ran the power wires from the EFIS, EIS, Radio and Transponder to avionics bus. Clean the cabin as it was getting filled up with things I still have to do but was in the way. I ran both the radio and transponder antenna wires from the back of the panel to the fuselage.
