Using the ratcheting wire crimpers I crimped on 1/4" wire connectors on each of the CHT 12 wires and ran them through sleeves to help keep wires from rubbing. I cut a 1/2" piece of tubing and ran a wire tie through it to supported the wire runs and off set them from any chance of rubbing. Like Don says an hour here and an hour there and we can get this done. I did not realize how much the wings were in the way until I moved them to the hanger. Sure is easer to work around the plane now.
