I did not like the set on the rudder when I set it up with the rudder peddles so I removed the Nicopress fittings and locked the rudder in place and redid all the Nicopress sleeves on rudder and aileron cables by swaging the Nicopress sleeves in the center first, next to the thimble second and furthest from thimble third. Make sure to use the gauge to check your Nicopress sleeves after swaging. Moved one of my work tables and the engine cowling to the hanger.
