Sanded out my runs on the parts from yesterday and re-primed. Well only half had runs on them so I was getting the hang of it at the end. Cleaned the wing with the EcoClean and EcoEtch and dried off for three hours in the hot sun. Even the inside was good and dry after all the rinsing was done. I noticed some zinc primer wicking after the parts were painted and am working on correcting that on some of the parts so I wanted to make sure all was dry. The parts that had some wicking covered well after the next extra coat of primer but I sure did not like it so you have to make sure the parts are really dry. Tomorrow I will apply a color coat on the wing and let it set for the 24 hours and then clean and prime the second wing.
