Started moving things around and building the wing paint stands for the paint booth. Stands are made out of scrap pipe so cost was only for the casters and the welding rod. Stands will allow me to rotate the wings when I paint them. I am using the Stewart Systems paint and following their directions on prep and painting. I will be using a turbine sprayer system that has supplied air also. The Stewart System paint is a High Performance Catalyzed Waterborne Coatings for the Aerospace Industry and not water based paint. You can get away with just using a charcoal respirator. Their web page is at www.aircraftfinishing.com
