BushCaddy ELSA
Date:  6-13-2008
Number of Hours:  3.50
Manual Reference:  None
Brief Description:  Nut plates
Yes the nut plates are on and riveted and now to continue on to the next part. Today was all about nut plates 58 for sure and eight rivet nuts. I do not use the special tool to do this> I run the screw in from the back and run the nut plate on the front. Drill a 3/32 hole for the first rivet and cleco in place then drill the second rivet hole. take it apart and place the nut plate on the back and cleco one hole then rivet the second hole and remove the cleco from the first hole and rivet it.
