Using the info found in the new Jabiru 3300 engine installation workshop from homebuiltHELP DVD I installed the gull wings between the cylinders, installed air dam at front of cooling air rams, added backing plates to the fiberglass air ducts, installed the spring clips and springs for the back of the air ducts. Fabricated and installed front baffles made from aluminum. Trimmed the carb air outlet on air box to make a smooth transition.
