BushCaddy ELSA
Date:  5-7-2008
Number of Hours:  1.50
Manual Reference:  None
Brief Description:  Mounted air cowlinf for engine
Mounted the engine cooling cowling by removeing three valve cover screws #1, 3, & 6 on each side and fitting cowling on the inside to slide between the cooling fins and marking for the valve screws and notching for the oil lines. Installed 2" prop extenuation
