BushCaddy ELSA
Date:  12-15-2007
Number of Hours:  1.00
Manual Reference:  None
Brief Description:  Heat muff
I started fitting up the heat muff. I had to cut a 2” hole in one side of the heat muff to slip over the tail pipe and it worked great. I set the scat hose connections in place and marked for best access to clamp the cat hose and the best follow for the hose to components and NACA air scoop.
