BushCaddy ELSA
Date:  12-15-2007
Number of Hours:  3.50
Manual Reference:  None
Brief Description:  FWF and engine
Worked on FWF Installed engine back on engine mount and installed on Fire Wall. Set battery box and clecoed in place, Drill through fire wall and installed fitting for Cabin Heat control cable, Carb Heat control Cable, and Choke Cable and ran cable through fire wall. Installed heat muff and modified to fit muffler. Set scat hose connecters in place and marked for welding. I had Jabiru send me my heat muff without the scat hose fitting welded so I can set them for the best running of the scat tube to the associated composites.
