Ran conduit and shielded electrical wire through fuselage and up the front of the vertical stabilizer for Navigation and strobe light on the tail. I had a set of running lights that I ordered with the kit and after looking at the amp load I decided to go with the Kuntzleman strobe and nav lights. With the 3 combo head set I should draw about 4 amps with nav lights and strobes. The system uses a single driver and the kit comes with all the shielded wire and connectors. If some one is building a tube and fabric plane and has tubes on the tip of the wings it even has the adapters for that. Now I can start riveting the right side of my fuselage on and close up the tail after I finish tie rapping the conduit in the fuselage.
