Worked on rigging aileron cables and discovered I will have to shift the bottom pulley inboard some as the aileron cable is rubbing the rudder cable on the left side. Have not worked on the right side yet but will do so tomorrow. Work on the control system is a little more time consuming then I thought it would be but I want it right. I know I have identified some short comings in the parts and the drawings on this kit as I have built, but all and all it is a very well made kit and will be a great plane when it is done. The drawings are easy to follow and this is the first plane that I have built and am enjoying it. I would recommend this kit to anyone that wanted and all metal plane and a very strong. It will be worth more than you paid for the total kit when completed.
