Drilled the ends of the rudder peddles for the AN3 bolt and shackle as per drawing section J A-C-S-008 and using the hand held NICO press I installed the NICO press sleeve and thimble to form an eye in the rudder cable ends and shackled it to the rudder pedals. I completed this on both sides of the rudder pedals. I removed PF-187L rudder pedal spring attachment point on firewall as it was interfering with the rudder pedals. I attached the left spring through the bolt hole that was there for the PF-187L part and then attached it to the right rudder pedal. Now there is no more interference and the rudders work freely. I was told that this is now how they do it and do not use the PF-187 part there. I am surprised how long it takes to do the controls and all the little things that are there to be done.
