The control rod ends have adapters J-293 installed for the 5mm rod ends. ( The drawings show 6mm). After finding the parts that I had put away in a safe place I measured out for four rivets space at 90 deg apart. Drilled and deburred the rivet holes and using the ccps 4-8 rivets that were included in the kit I riveted the rod adapters in place. Removed the landing gear to take to be powered coated. Painted J-266 and J-268 gloss black
