Drilled nose ribs, main ribs and trailing ribs and U-14 stringers for the top of the wing. Dismantled left wing ribs and spars and deburred and stored until after the Arlington Fly-In. I will work on little things that are still need to be done to the cabin and fuselage. Cut the last of the Lexan for the doors and drilled. Painted door frames black and started riveting the Lexan in place. Purchased hinge stock from Wicks to finish the left door.
