Finished drilling the rivet line on the skin to ribs and laid out and drilled rivet line for skin behind fuel tank. Drilled fuel tank edge for rive nuts. ended up at 125mm spacing. Found one rib line off after drilling and will have to use some 412 rivets there next to the 410 that I had to drill for were the rib is. Glad I am painting this plane.
