Brief Description: Finished setup on right front wing spar
Setup and drilled PK-352 backing plate and PK-349 and deburred all the parts. PK-352 is not shown on the forward spar but is needed. Rick said the new drawings will reflect this. PK-356, PK-352 and PK-349 use three 512 rivets instead of the 410 rivets for jury strut attachment. I will be off this weekend and will prime the right wing spar Monday and then will they dry start the left wing spars. PK-349 and PK-356 should extend down from the spar 40mm.
