I re-adjusted to the right seat sliding frame as it was not sliding easy. After completing the left seat I started the right seat with some adjustment in the rivets on the UHMW. The rivets should be set in as close as possible to the side of the angle as is possible because the angle that is used to keep the seat in the slide extends past the half way point and the rivets will interfere with the sliding of the seat.
