BushCaddy ELSA
Date:  4-19-2007
Number of Hours:  0.50
Manual Reference:  Section H
Brief Description:  Installed door handle on right door
Installed the right hand door handle 150mm back from the front edge of inside side of the door frame. Drilled a 3/8" hole. On the back of the door handle cover is two locating pins. I aligned them fore and aft and tightened the nut on the back side of the handle. This marked the location of the two locating pins on the door skin. Then I drilled out the marks just big enough to allow the pins to lock in to them.
out side door latch
out side door latch
inside door latch
inside door latch
door latch
door latch
