BushCaddy ELSA
Bushcaddy E-LSA
Bolt Torque
I found bolt torque for all the bolts with the exception of AN3 and after much searching I found it so here is the info for you.
The common bolts are AN3, AN4, AN5 and AN6. The following are torque values in INCH POUNDS using standard fiber nuts.
AN3 20-25
AN4 50-70
AN5 100-140
AN6 160-190
Bushcaddy E-LSA Home
737
Ailerons
Cabin
Cabin to Fuselage
Cargo door
Cowling and nosebowl
Doors & Windshield
E-LSA Kit complete
Elecrtical
electrical wiring
Elevator
Engine mount
Fire Wall Forward
Horizontal Stabilize
Inspection
Interior Finishing
Seats
Technical Advisers
Tip
Vertical Stabilizer
156
