I riveted PF-120 and PF-117 in place. Attached PF-122, PF-172, PF-115, PF-116, MS24566-3B and PF-206 using supplied bolts as per drawing. Placed and held PF-188, PF-206, PF-202 and PF-203 temporarily to drill for bolt holes. PF-202 and PF-203 are different then pictured in the drawing. Drilled and clecoed PF-163 in place. I primed PF-162. The drawings for the fire wall show to use SSD44BS rivets but after working with Rick in Utah I found out that the right rivets are SSPS44 and the kit includes 150 of them. I will do that next. On 9-02-07 I was working on aileron cables and discovered that I have the bottom pulleys to far out and had to relocate them.
