Brief Description: Riveted and installed cabin parts primed
Riveted cabin top gussets PF-128 and fire wall gussets F-138-T, F-138-B PF-150, PF-137, PF-165, PF-166 PF-6043 and PF-6044. using 426-4-6 and 470-4-6 rivets and 470-6-8 on corners. I used 426-4-5 rivets on PF-165 and PF-166. PF-199 and PF-200 were not included with the kit so I made them to fit after talking with Rick. Installed throttle controls 197 PF-201 using supplied bolts. PF-201 is drilled for two bolts and is split on one side. You only need one bolt on the non split side to hold it in place. The center plastic peace is used to adjust tension on the control rod to hold throttles. Attached PF-194 with AN3-5 bolts and nylock nuts. Placed and drilled PF-148 for bolts but did not install because it will be removed to do top skin.
