Brief Description: Alignment of bulheads and top U stringer
After setting up bulheads A-001 and A-006 set bulcheads A-002 through A-005 at the marks on the table and lean each bulckhead back the reguired 87 deg. Install A-014 on top of frames. Some U stringers will need to be spliced as per drawing U stringer splice. Do not splice stringers between A-001 & A-002 or A-005 & A-006. Stager splices as you make them. Do not get ahead of yourself on the sides. Follow drawings in order.
