Bill and I installed two relays and a negative bus bar in the nose firewall. We installed a negative bus bar, 100 amp fuse and the amp gauge shunt on the rear firewall. Bill constructed the 4 gauge wires and attached several while I sanded the overhead panel for paint. We also had a little tech problem with the cooling fan and chased that down to a bad connection, so that is fixed!
