Bill finished up the Autopilot disconnect at the flight control stick. We hooked up the servo motors and tried them out. The elevator servo moved backward and will require a jumper between pins one and two. The aileron servo worked but had issues. Apparently it didn't like the input. We will have to run down the wires. I put on the temporary decals for the callsign. I also put up the experimental and passenger warning placards.
