The Flight control stick was reinstalled, flight controls connected and checked. The intercom / headset jacks are wired. The speedbrake and aileron trim motors wired and tested. Oil and filter change. PSRU oil change. New Champion double platinum spark plugs installed. Water temperature sensor correctly rewired. Engine run and all the sensors check out with the Dynon EMS!!!!!
