You may have heard of the flood in Chehalis Washington. Well after several weeks of cleanup in the hanger I finally got a chance to start working on the plane part of it. The aileron servo found water and I removed it from the airplane and took it apart. Yup sure enough there was water in it. I dried it out and lubed it up but I will need to bench check it before I put it back in the plane. The rest of the day was spent cleaning flooded cuboards.
