While Bill finished the layup for the rear panel mount I cut, fit and installed our new CH Flightstick. Hatswitch for elevator and aileron trim, push to talk trigger, auto pilot disconnect switch and two switches to be used , in our case for radio channel change......very cool!
I also mounted the outside air temperature probe in the fresh air inlet.
Then Bill and I ran all the antenna coax down the inside of the keel. We installed adel clamps to keep it free from the speed brake actuator and brought it out just behind the panel where the radio stack will be.
