I tightened the autopilot mounts and adjusted the linkage, all are free and clear and working well. I fashioned a mount for the Dynon fuel flow sensor, mounted it on the firewall correctly this time and re-routed the fuel lines accordingly. I ran the oil pressure line from the engine port to the firewall and mounted the hobbs and oil pressure sensors to the firewall. Now to start wiring!
