Wow, Lousy couple of months around here but I finally made it back to the hanger.
I finished all the layups that form the lower scoop and actually got some mud on the thing to start the finish work.
It is cold here and it will be a slow process. You may note the propane heater in the background that helps keep the area warm. I'll either finish the cowl this winter or blow up trying!
