Brief Description: Landing Lights mount plate work
Started drilling Landing Light top rivet points. Seemed to go well. Then remeasured and drilled some of the bottom rivet points. Couldn't get the flange forward enough. It looks like I might have to redrill further aft. This sucks because I had measured, and remeasured from the spar. The skin pilot holes (that I drilled), when lined up as good as I could, looked to be almost on the rib front bend.
Going to bed to step away from it for a while to think.
