Note. Got answer from Zenith. He said that the issue with the non-rounded out hole on the mass balancer probably wasn't going to be an issue, but to just keep an eye on it. I figured since i hadn't closed the other aileron yet that I should go ahead and clean up (round the corners) of the Left side aileron mass balancer arm (6W12-1) hole.
Email response: "I think you're fine leaving it the way that you have it. I would just keep an eye on it."
