Larry Winger's 601XL Project
Date:  4-2-2009
Number of Hours:  2.50
Brief Description:  Worked on seat area
Tonight I did more painting (yes, there always seems to be something to paint), then I riveted in the floating nutplates in the front seat panels and arm rest sides. Before temporarily putting things together, I also bolted on the forward torque tube bearing to the center spar. The plans call for AN3-4 bolts, but I found that did not leave two threads protruding above the nut, so I increased to AN3-5 bolts and put a washer on both sides. It worked just fine. It sure is great to see things coming together this way.
Things shaping up
Things shaping up
Access covers installed
Forward torque tube bearing mounted
