Larry Winger's 601XL Project
Date:  10-22-2011
Number of Hours:  3.75
Brief Description:  1 - Made cover for channel and routed battery wire
After going back and forth on best routing, I landed on going through the bottom channel with a cover installed. This represents the most direct route and presents the fewest problems in terms of routing through or around the center spar. I fabricated a cover with a closed front end to avoid sucking in hot air from the engine. I then drilled the entrance and exit holes for the 2 AWG cable. Next I'll secure it with Adel clamps as needed to get it back to the output side of the battery contactor.
Routing of 2 AWG wire from firewall to bottom channel opening
Wire running through bottom channel
Bottom channel cover on
