Larry Winger's 601XL Project
Date:  8-10-2007
Number of Hours:  3.75
Manual Reference:  6W6-1 to 9
Brief Description:  Completed forming wing ribs
Tonight was the night. I completed banging out my wing ribs! I'm quite pleased with my workmanship, and expect that things will fit together well. I even had the energy to spend an extra 30 minutes cutting the 115mm holes in the right wing ribs. As I've mentioned before, I use a fly cutter in my cordless drill and it works really well. I wouldn't consider doing it any other way (some of which I have tried and found very lacking). With an open schedule tomorrow, I expect I will be able to cut and flange all the lightening holes, then finally tweak all the ribs.
All 9 ribs on the left wing
Bottom of the wing
Bottom of the wing
Right wing ribs with 115mm holes cut
