Larry Winger's 601XL Project
Date:  5-21-2007
Number of Hours:  2.25
Manual Reference:  6W3-3 to 5
Brief Description:  Pre-drilled spar caps and one angle
Set up my drill press against the side of the worktable and made sure it was level and secure. Then I used the #40 bit to pre-drill both spar caps. Next I stacked the bottom doubler and pre-drilled through the caps to match.
