Larry Winger's 601XL Project
Date:  7-21-2006
Number of Hours:  0.00
Brief Description:  Completed work table
Picked up the lumber and fasteners at Lowe's after work and completed the frame and top of the work table. Used the marble entry to our house for a flat, smooth surface to start the process. Put down a 4 x 8 sheet of MDF which I shimmed to make it level. Laid out the three I-beams and made sure they were level as well. Attached the plywood ends and trued up the corners. Put down the 3/4 plywood first, then topped it with 3/4 MDF. Very straight and true. For the time being, I have the table on saw horses, but will put on adjustable legs before any critical assembly takes place. Now, at least, I have a place to work and lay out parts and supplies. (Time: 7.0 hours)
