Brief Description: Drilled bolt holes where necessary
I finally determined that 10 rivet holes had been compromised while removing the solid rivets. Starting just one step above the 3/16" diameter of the holes, I then used drills lettered A through E, followed by the 1/4" reamer to prep the holes for the AN4 bolts.
