Brief Description: Installed gascolator and fuel pumps
To get from the firewall to the hose delivering fuel to the carburetor takes 10 different parts, all in alignment with each other and correctly positioned on the firewall. Today I pulled it all together and moved one step closer to engine installation. As you may be able to see in the 2nd picture, the mounting bracket for the bottom fuel pump overlaps with the new CH 650 steering rod slide covers. Fortunately, I was able to trim away the lower part of the bracket without causing any mounting problems.
