Larry Winger's 601XL Project
Date:  6-7-2009
Number of Hours:  2.25
Brief Description:  Reassembled canopy latch system
After painting everything, it was time to reinstall. In order to pull the canopy frames firmly to the longeron doubler surface, I added extra washers (above the 3 that are called for) between the extruded latch hinge and the bottom of the longerons. That brought them right where I wanted them. I also ended up remaking the arm on the passenger side to shorten the distance between the O/B tube arm and the latch (to pull the latch down tighter).
The big picture of canopy frame and latch
Latched, and ready to open
Handle down, latch released
