Larry Winger's 601XL Project
Date:  5-22-2009
Number of Hours:  0.00
Brief Description:  Error on 650 canopy latch drawing
I just confirmed with Caleb this morning that the location of the pivot bolt hole on the Extrusion latch Hinge (65-C-4-2) is reversed in the drawing on page 6-C-4. It shows the hole 30mm from the back end of the part and it should be 30mm from the front end. Normally this wouldn't be a big deal if the bolt was held in place by a nut (after inserting it through the latch). Instead, the plans call for it to be welded. It's a little tough to flip the latch around at that point!
