Brief Description: Installed torque tube and supports
Installed rear torque tube bearing and support (last picture below), temporarily placed the forward torque tube bearing between uprights in the center spar (first picture) and then leveled the tube (second picture). Once things were level, I clamped the forward bearing and step drilled the part in place. An elegantly simple design that controls the ailerons -- causing the airplane to raise or lower the wing, usually to aid in turning.
Looking back from the center spar through the seat back
