Brief Description: Added baggage floor bracing and corners
Measured and marked intersection of bracing with floor, cut Z angle and drilled, lined up and drilled through to the upper channel (6-B-5-3) and installed the L angles in the front corners. Quick to type, but not so quick to do.
