Larry Winger's 601XL Project
Date:  12-18-2007
Brief Description:  Installed tank senders/fitting and tested tanks
I borrowed three 5-gallon fuel cans from the hangar and put 4 gallons in each (since my fuel tank capacity is 12 gallons). Next I reinstalled my fuel senders, this time with EZ-Turn on the face of the rubber gasket and on the 4 or 5 threads closest to the head of each screw. I also used EZ-Turn (a comparable product to Fuellube) on the fuel drain and finger screen threads. Nothing was used on the male/female AN parts. While I filled each tank, Joy watched for any sign of leakage, and the good news is that her job was totally boring. No action whatsoever. When it came time for tank #2, we moved the first tank to a higher level and drained the fuel. I put ohm meters on both to see if the fuel senders were working. As one was going down, the other was slowly rising. Very cool. Now I get to top off the third fuel tank of the night...the one in my Honda Pilot. My wing tanks are ready to install.
My test stand
My test stand
Draining tank 1 into tank 2 - Joy watching for leaks
Braided hose with AN-6 fitting and plug to seal for test
