Larry Winger's 601XL Project
Date:  11-23-2007
Brief Description:  Installed & tested left tank fuel sender
I probably re-read the photo guide four or five times before commiting myself to this process. I didn't find the guide to be exceptionally clear, so I really wanted to check and re-check my thinking. That's why this took 2 hours. The next tank should take 45 minutes. Before cutting into my fuel tank, I decided it was best to make the same sized hole in some scrap aluminum to be sure my fly cutter was set properly and that I knew how I would mount the sender through the hole. Once I was satisfied with that, I identified the location of the hole center on my tank. Using the fly cutter made a 59mm hole, which I deburred and smoothed. Next I flushed all debris out of the tank with air and water. After the tank was reasonably dry, I installed the sender. In order to secure the ground wire, I used an AMP crimp ring connector with 18 gauge wire and some heat shrink for more rigidity. Finally, I hooked up the ammeter and everything read perfectly. 10.4 ohms full and 69.2 ohms empty.
Ready to hook up
Ready to hook up
End view with profile of identical unit (float on empty)
Same view, but float on full
