Larry Winger's 601XL Project
Date:  7-28-2007
Number of Hours:  6.00
Manual Reference:  6W6-1 to 9
Brief Description:  Work on wing rib forms
Because I was using the DWG files from the www.601org website, I thought it would be best to triple check all dimensions. Form by form I checked lightening hole size and location, drilled 1/4" holes in the center of each, and marked the relief crimp locations. Next I carefully inspected each form for additional sanding required. The next step was to put a radius on the matching inside edges of the forms with a 1/8" roundover router bit. Then I set up the sander for the 10 degree chamfering (allowing spring back when forming the ribs). I only did one rib because I was getting maxed out on work in the shop. Before quitting for the day, however, I did sand out the 25 degree relief crimps on the #9 rib form. One down, eight to go!
Fine sanded and marked for crimp reliefs
The bottom side of the wing rib form blocks
My first completed wing rib form block
